Nested repeat relevant fields clearing when viewing and/or editing from inbox
1446
05-01-2024 12:10 PM
BrookeHehr
I'm having issues with relevant answers clearing/lost that have a relevant filter located within a nested repeat. The questions are cleared when viewed or edited from the inbox.
The questions have the same relevant calc of selected(${TreatmentTyp},'Herbicide') where TreatmentTyp is in the same nested repeat, one question before the three relevant field questions.
I have a nested repeat with "query" in the bind::esri:parameters field for the repeat group to load previous repeat records in. All other questions in the nested repeat are appearing/loading as expected before and after the three relevant questions.
Is this a known issue for nested repeats?
BrookeHehr
Solved - I moved my relevancies from the relevant column into the body::esri:visible column and that solved the issue. Similar issue was happening in this post Solved: 3.14 - Fields with calculated relevancies are clea... - Esri Community
BrookeHehr
