Need group access to Survey123 home page
794
11-15-2016 11:54 AM
GarrettStarks
I work for an organization with a team of inspectors doing field work. We would all like to use the same survey to collect our data, but it appears only the creator of the survey can log in to the survey123 homepage and analyze/export the data collected. This will make things much more complicated for us. Is there a way to give everyone in our group access? I heard a rumor that this would be a future update, but I'm not sure when that will be happening. It would be a very helpful feature. Thanks!
DerekLaw
Esri Esteemed Contributor
Hi Garrett,
> ... only the creator of the survey can log in to the survey123 homepage and analyze/export the data collected. ...  Is there a way to give everyone in our group access?
As you mentioned in your post, this functionality is planned to be part of the next Survey123 for ArcGIS update - sometime in December. To learn more, please see this blog post:
https://community.esri.com/groups/survey123/blog/2016/11/07/ensiheim-meteorite-strike-day-release-19
(look under the What is coming next section)
Hope this helps,
GarrettStarks
Great! Thank you for your help!
