Multiply then divide
3049
10-27-2021 09:31 AM
JaredPilbeam2
Is it not possible to do this?
${carpetyards} * 84.4 div 2000
 I'm not getting an error but I'm also not getting a result.
jcarlson
Not sure how the order of operations works in S123, but I can get a similar expression to work just fine.
How is your carpetyards field formatted? Is it possible the form is reading it as text? When I enter a string like "8,800", it fails to compute.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
JaredPilbeam2
Josh,
The carpetyards field is an integer type.
It wasn't (isn't) working in S123 Connect, but it is in the web app. Go figure. But, I guess I have a new problem. It isn't showing decimals?
I'm no good at math, but my calculator tells me 66 * 84.4 / 2000 = 2.78.
jcarlson
You have tons set to an integer as well. Set it to decimal to fix that.
- Josh Carlson
Kendall County GIS
JaredPilbeam2
That did it. Thanks a bunch.
