Multi-select returns different statements based on order of selection
801
09-23-2024 07:00 AM
dwold
I have a multi-select question that returns different statements based on the order of the the selection. That is not the intended outcome I am looking for (I want the user to be able to select in any order and return the correct target statement) but I am having issues allowing the user to select choices in any order and getting the correct statements to display.
Correct statements when selecting top to bottom:
Bottom to top selection (Reopening Business is selected first)
Selecting Reopening Business then Long_Term unemployement
I have attached my form and the pulldata table I am using
abureaux
MVP Frequent Contributor
That is the expected outcome for what you have set-up.
In the file attached, these notes are showing the text:
And those calculates are here:
These calculates will 100% be different based on what order you selected items. That is how selected-at() works.
As for how to fix... I'm not sure off-hand. You have a surprising amount of things going on for such a small form. I feel like it could be streamlined a little.
abureaux
