MS Flow Webhook - Error (TrustFailure)
6356
11
06-13-2019 04:11 PM
MarcoPoetsch
Hi all,
I creadet a MS flow to capture records. This worked fine for quite a while. However, since yesterday I get following error message on MS flow:
BadRequest. Http request failed with status code 'TrustFailure' and status message: 'The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.'.
The survey is hosted on AGOL.
Even if I create a new connection I get the same error.
On MS Flow site:
MS FLow Error
On Survey123 site:
ÉricGosselin
Thank! I will test this !
AndreiaKerber
Good afternoon
I was having this problem in the days and managed to solve with the following:
I enabled my AGOL account to use https .;
After that I removed all connections that existed in the flow with Survey123;
I opened my flow again and added the connection;
On mobile devices I deleted all existing searches and downloaded them all again.
I performed a test on 3 smartphones.
My flow came back normally.
I realized that it was something in this sense, since the searches registered via the web flow worked normally.
