Microsoft Power Automate - unable to select an existing survey
3753
05-05-2022 03:58 PM
BrianHall7
Trying to use Power Automate to create an email notification when a survey response is submitted. I am unable to select a survey from the “Choose a Survey” drop-down. Any tips for when you get “Could not retrieve values. The dynamic response could not be parsed.”? Any guidance for what a custom value is in this case?
HeatherBuchanan
Actually, I just found a similar support article:
Problem: The drop-down list does not display surveys in the ArcGIS Survey123 trigger in Microsoft Po...
I went back to my connections and selected "Switch Account" and signed back in.  Everything seems to work now!  Hope this helps!
HeatherBuchanan
Was this ever resolved?  Been using Power Automate with Survey123 triggers for some time and am suddenly having this issue.
HeatherBuchanan
Rama1356
This answer saved my day! Thank you
BrianHall7
Honestly I dropped the issue back then. Trying again today, no change. I can't follow the support article you provided because my agency blocks third-party cookies by default, and I don't feel like arguing with I.T. again. 🙂  Another GIS person in my agency is/will be setting up some Power Automate flows soon; I'll forward the article to him. Thanks!
BrianHall7
OK, the solution you provided via the support article works for me if I use Microsoft Edge. I was using Chrome before.
