media::image alignment
5126
12-12-2021 06:06 AM
JenMcRuer
Hello,
Is there a way to align (left, right) images entered into the media::image column, to override the default centred alignment?
Thanks.
FrankOuyang
I don't think this option is currently available. Please see this previous post.
FrankOuyang
JosephKelly
I was looking for solutions to aligning and resizing an embedded image when I ran across your question. I realize your question is nearly 4 months old, but I believe I have a solution for you.
Survey123 Connect supports HTML formatting in the "label" column. I used the img HTML tag, added my parameters, and it WORKED! I attached an image.
the code is as follows (provided the image file is saved in the media folder of your Surve123 project) :
<img src="fileName_as_it_appears_in_mediaFolder" alt="Alternate Name" width="0000" heigth="0000"  style="align">
I Hope This Helps
Joseph Kelly
rwrenner_esri
Esri Alum
Joseph's solution above is a great workaround. Also wanted to note that the same method works in the hint column in case that's better for your formatting use case. (E.g. so the "required" star doesn't appear after the image.)
mikaël
To align right, instead of using the style="align" parameter, I used align="right" inside the <img src> tag.
