Max-Height in Survey123 Notes
1408
07-26-2019 07:54 AM
JamesMertz1
Greetings,
I am running into a 300 pixel image restriction for max-height in notes in Survey123.
I am currently using the desktop version of Survey123.  I am using reference images and map images in notes to provide survey context.  In the survey preview the images are full-size and scale perfectly regardless of device.
When published to the web the max height on the images is limited to 300-pixels.
You can see that I tried a workaround to include a link to the full-size image, but unfortunately that was not sufficient for our users.  I have tried to override in the xml files, but that gets overwritten when republishing to the web.  I can temporarily fix it by turning off the Max-Height in the browser.  Hoping for a more permanent solution.
Has anyone else seen this?
Jim
JodyZhengLiu
Hi James,
Currently there is no way to modify that, but we will have the Survey123 JS API in beta soon, which supports custom styles:
You could sign up for the Esri Early Adopter Community https://earlyadopter.esri.com and join the Survey123 project to get access to beta features.
Jody Zheng Liu
