Lenovo Tab4 8 with Android 7.1.1 - certificate issues
1454
07-19-2018 04:30 AM
DeonLengton
We have a client that have an Portal installation and Esri apps for the field work (Survey123, Workforce, Collector)
In short: Survey123 does not log in when using a local certificate authority certificate but works fine when using a public certificate:
  1. Client’s GIS and Planning Unit server is back facing and not public facing
  2. Due to the above they require security certificates to allow for communication between the 3 apps we use (Workforce, Survey123 and Collector) and our ArcGIS Portal
  3. Initially they had these deployed on Lenovo Tab4 8’s (Tab 4 8 | A Premium 8” Tablet for the Whole Family | Lenovo South Africa ) which initially had Android 6.6 – The apps ran perfectly
  4. They then did an OS update on the tablets to Android 7.1.1
  5. Unknown to them, Android 7 has new security protocols that do not read user uploaded certificates
  6. This then caused SSL handshake errors between the apps and our portal
Does anyone know how to work around this problem?
JohnathanHasthorpe
Hi Deon
Please email me about this: jhasthorpe@esri.com.
Thanks
John
KaraUtter
Was this issue figured out? Because our organization is looking into Lenovo as a possibility for replacing some of our Tab A's and we frequently use Collector and Survey 123
JohnathanHasthorpe
Hi Kara
This is not a Lenovo issue - it is a portal certificate issue. So you are fine to proceed. Just ensure that the Android version meets the Survey123 minimum requirements: System requirements—Survey123 for ArcGIS | ArcGIS
Thanks
John
KaraUtter
Deon, I am leaning toward the Lenovo but want to ensure one thing - can you tell me whether Collector for ArcGIS allowing the connection with the external sd port for additional storage with this device? I'm assuming that there won't be any issues but I want to make certain because the external sd card storage basemaps are important for our projects.
IsmaelChivite
Esri Notable Contributor
