Label starting with <= no longer working
231
06-12-2020 10:31 AM
DougBrowning
I have a form that has a label of <= 2mm and all of sudden it will not show - it used to work.  If I add a space like < = 2mm it works.
What is up here and when did it change?  v3.9.120
Shwu-jingJeng
Hi Doug,
What version of the Connect that worked with the string "<=" in the label?
I tried the previous versions of Connect and <= won't work as it was treated as part of HTML syntax in Connect.
But if you use ≤ sign, this will work.
Could you check what version of Connect did the string "<=" work for you?
From my testing, ≤ sign has to be used in any version of Connect, otherwise, <= would be misinterpreted as part of HTML syntax.
