JS function works in web form but returns error in mobile app
1637
05-03-2024 12:50 PM
KellyTaylor
Can anyone tell me why a javascript function I'm using in one of my surveys works great in the web form but gives me a type error when I submit in the mobile app? Any advice would be much appreciated. Lots of details below.
I'm not great with javascript so my function is probably clunky. It is intended to take the responses from a select multiple question, remove "Other" (if it's in there), sort the rest alphabetically, and return it. It works in survey123 connect and the webform.
function sortString(inputString){
	let anArray = inputString.split(",");
	let len = anArray.length;
	let other = -1;
	if (inputString.includes('Other')){
		other = anArray.indexOf('Other');
		delete anArray[other];
		anArray = anArray.sort().splice(0,len-1);
	else{anArray=anArray.sort();}
	return anArray.join(',');
This screenshot shows the result if I submit using the web form (works as expected) and the result if I submit using the mobile app (the type error)
Here is an abbreviated version of what my xlsform looks like with only the relevant questions and fields shown.
The idea here is that the user selects from a list in "cleanup_null1". Those selections then get sorted alphabetically (minus "Other" if they selected it) in "cleanup_sorted". Then they enter more information in "cleanup_other1" if they selected "Other". The final result is in "request_cleanup_type" where it either stores the "cleanup_sorted" or a concatenation of "cleanup_sorted" and "cleanup_other1"
The only response that is sent to the source layer is "request_cleanup_type", and the only fields visible to the user are "cleanup_null1" and, if they select "Other" then "cleanup_other1"
type
name
label
calculation
relevant
bind::esri:fieldType
select_multiple cleanup_type
cleanup_null1
Request Cleanup Type
null
text
cleanup_sorted
sorted
pulldata("@javascript", "functions.js", "sortString", ${cleanup_null1})
null
text
cleanup_other1
Request Cleanup Type: Other
selected(${cleanup_null1}, 'Other')
null
text
Requested Cleanup
if(selected(${cleanup_null1},'Other'), concat( ${cleanup_sorted},',',${cleanup_other1}), ${cleanup_sorted})
ZacharySutherby
Hello @KellyTaylor
The field app is passing the select_multiple values in as an array so the split() method is throwing the error. Try:
function sortString(input){
let inputString = input.toString();
let other = -1;
Thank you,
Zach
ZacharySutherby
Hello @KellyTaylor
let other = -1;
Thank you,
Zach
KellyTaylor
Thanks so much, that did the trick!
