I would like to write JavaScript functions that can be directly used in the calculation column of geopoint and geoshape, as follows:
* JavaScript functions for Survey123
function getGeoPoint() {
// Add your code here
return "1.0000 2.00000";
function getGeoShape() {
return "0.0000 0.00000;0.1000 0.00000;0.1000 0.10000; 0.0000 0.10000";
However, the above JavaScript functions do not work and return the following error:
It seems that the expected output is not some space-separated values of latitude and longitude. What are the correct output from a JavaScript functions that can be directly used by geopoint and geoshape? I can't find such documentations.
@JamesTedrick Grateful if you can shed some lights on this problem. Thanks.
As a workaround, modify the calculation column using the following syntax:
string(pulldata("@javascript", ...))+" "
string(pulldata("@json", ...))+" "
