JavaScript functions for Geopoint or Geoshape
1393
08-08-2022 03:15 AM
WPG03WPG03
I would like to write JavaScript functions that can be directly used in the calculation column of geopoint and geoshape, as follows:
 * JavaScript functions for Survey123
function getGeoPoint() {
    // Add your code here
    return "1.0000 2.00000";
function getGeoShape() {
    return "0.0000 0.00000;0.1000 0.00000;0.1000 0.10000; 0.0000 0.10000";
However, the above JavaScript functions do not work and return the following error:
It seems that the expected output is not some space-separated values of latitude and longitude.  What are the correct output from a JavaScript functions that can be directly used by geopoint and geoshape?  I can't find such documentations.
WPG03WPG03
bump
WPG03WPG03
@JamesTedrick  Grateful if you can shed some lights on this problem.  Thanks.
WPG03WPG03
As a workaround, modify the calculation column using the following syntax:
string(pulldata("@javascript", ...))+" "
string(pulldata("@json", ...))+" "
