Issues With Group Items Spanning Multiple Columns
1919
05-25-2023 01:33 PM
DavidSolari
MVP Regular Contributor
According to the docs, if a Survey group has columns it should be possible for a child item to span multiple columns. I can't seem to get this working at a basic level, what am I missing? I've attached a minimal example form, the "Additional Comments" should span the width of the group but it's currently showing up in just the first column. Thanks in advance!
ZacharySutherby
Hello @DavidSolari
In the settings worksheet you will need to set the style to either fixed-grid or dynamic-grid. Please see this documentation for more information on the difference between the two options.
Thank you,
Zach
ZacharySutherby
Hello @DavidSolari
Thank you,
Zach
DavidSolari
Ah, I was setting it just on the group's style, I guess you have to set it on the entire survey. That works perfectly, thank you!
