Issue with Select One Question Autocomplete in ArcGIS Survey123
8238
10
12-22-2023 08:53 AM
arc_ticodex
I've been working with ArcGIS Survey123 and encountered a potential bug related to the "select one" question with the autocomplete appearance.
In my survey, I have a lengthy list of domains for the autocomplete appearance. However, when scrolling down through the list, I've noticed that the dropdown unexpectedly closes before reaching the end. This prevents me from selecting options beyond a certain point in the list.
Has anyone else experienced a similar issue, and is there a known solution or workaround? I would appreciate any insights or advice on how to address this problem.
(view in My Videos)
PatrikRalsberg_Tucumcari
Hi Ruth,
I have also found the same issue with Survey123 in ArcGIS Online.
The Survey123 version is 3.24.
I have tried both by adding search('csv_file_name') and Autocomplete in the Appearance column, but the pop with all the names appears still.
It would be awesome if this has been sorted out. Since this will be a public service, exposing our customer's employees like this is a big no-no. 🙂
