Issue with cascading selects
1400
07-27-2023 01:00 PM
JonLevulis
I am working on a hydrant test form and hope someone can help (I couldn't find this specific issue using the thread search).
I've entered a similar expression for each of the models in the choices sheet within the filter column.
In the last picture, only the first 3 results should be displayed.
DougBrowning
Not sure what the filter column is for?  You want to put just the value in a column in the list then in your select one use the choice_filter column to put the selected(${LoticOrLentic}, Gtype) part.
This is a good blog post on it  https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-choice-filters/ba-...
Hope that helps
DougBrowning
Hope that helps
