I have a list of survey's that I need the users to complete in a specific order at a specific location. If the Geopoint field is defined as read only they full page map will not open. However they need the map to know where to go. I have also created a hyperlink that would open a webpage or app but once again it does not show if the geopoint field is read only. If the small map could be made bigger by modifing one of the webform or xml files in the folder I would try that but I am not sure which section to edit.
Here is my calculation field to get the url. Once I make the geopoint read only the link is blank.
concat('<a href="http://maps.google.com/?q=', ${lat} ,' , ', ${long},'">Locations</a> Go Here')
Any ideas?
Hi Shane. It is not possible to make the map bigger in the form as you describe. However, here are some ideas:
We are using the inbox but the map has too many points for them to easily find the next one in the list. I tried the custom URL but without the ability to get the lat and long from the point there is no way for me to send any of the apps to a specific location.
That would work if the geopoint would return the values even when marked read only.
I did get it to give me the workorderID and was able to search explorer for that so for now that is what I am doing but location would be better. Especially if they have no cell service.
