Blank required fields being submitted - Survey123 bug?
4471
7
02-16-2018 02:01 PM
TylerGrosshuesch3
We noticed that a blank required field can be submitted in Survey123 if a user enters something and then deletes it. It doesn't seem that this is the desired behavior. We're seeing this on a variety of Windows computers. I notice the web survey does what I'd expect - if I enter a value and then delete it, the field is highlighted as an unmet requirement and the form can't be submitted.
Is this a bug in the Windows app?
Tyler
Tags (1)
JohnathanHasthorpe
HI Tyler - I have replicated this issue and the good news is that we have fixed this in 2.7.
You can test it out through our Early Adopter Program
JohnathanHasthorpe
Hi Tyler
Can you confirm the version of Survey123 and Windows you are using, and also do you have a survey xls that you could share? I have not been able to replicate this issue.
John
TylerGrosshuesch3
Hi John,
It's Survey123 2.5.44, Connect 2.5.44, & Windows 7 Pro SP 1. I saw the same thing on two other Win 7 computers and I can check the versions on those if necessary.
Two sample spreadsheets are attached. They both were mangled a bit by creating in Excel at work, then editing with Libre Office Calc at home, and coming back into Excel. That seemed to only affect validation & formatting in the spreadsheet, I haven't noticed anything in the survey that I'd attribute to the spreadsheet's validation & formatting quirks.
Tyler
JohnathanHasthorpe
Hi Tyler - I have not been able to replicate this.
Have you been able to test any non Windows 7 devices?
TylerGrosshuesch3
I just tested with an older iPad Mini and saw the same problem - entering and then deleting a value from a required field allows a blank entry to be submitted for that field. iOS 9.3.5 (that's up to date for this device), model MD530LL/A, Survey123 2.6.7.
I will probably be able to test with a Win 10 computer soon. All field users on on Windows 7 laptops.
TylerGrosshuesch3
I also tested on a Windows 10 Surface Pro and got the same results. This seems to happen with any numeric field. Please let me know if I can provide any more information.
JohnathanHasthorpe
TylerGrosshuesch3
Thanks!
