Is there a way to create a link from Dynamic Content in Power Automate that links to a feature in a webmap?
914
06-15-2023 09:03 AM
JAbbott
So long story short I'm working on a project with non-GIS folks and so far I've used Power Automate to populate an excel sheet that they can check for results coming in - it shapes up to be a cleaner experience with less explaining vs the s123 results console.
This leads to my question - is there a way to use any of the Dynamic Content fields captured from the survey (in Power Automate) to link out to the specific survey feature in an existing webmap?
I know it's a silly workaround but if it's possible I'd appreciate any guidance.
IsmaelChivite
Esri Notable Contributor
Check this help topic: https://doc.arcgis.com/en/arcgis-online/reference/use-url-parameters.htm
You can get the XY coordinates of the record to construct a new URL. Note that you have parameters to control the web map, zoom level and you can even add a pushpin at the location with a popup.
