Is it possible to merge feature reports for multiple records when generated in Power Automate?
620
07-02-2024 01:14 PM
CarlisleHaworth1
When a feature report is generated on the Survey123 management site, there is an output setting that allows reports for multiple records to be split into multiple documents or merged into one:
However, in the Generate Report action in Power Automate, that setting isn't available or it's at least not obvious. I'm setting up a scheduled flow to run once a week on all records submitted the prior 7 days and would like to merge them into a single document. Is this possible with the Survey123 connector or are there any simple workarounds?
@IsmaelChivite
ClayDonaldsonSWCA
I believe that this is not an option in the power automate action.
I was able to implement as an http action using a POST request:
Report | ArcGIS Survey123 REST
It has a paramater for merge:
mergeFilesfalseSpecify if print multiple records into a single report file (merged mode) or multiple files (split mode), and if in merge mode, start the next record on a new page or continue with the current page. Note: A merged file larger than 500MB will be split into mulitple files.
  • none: Print multiple records in split mode, each record becomes a separated report file. This is the default value if mergeFiles is not specified in the request.
  • nextPage: Print multiple records in merge mode, the content of the next record starts on the next new page.
  • continuous: Print multiple records in merge mode, the content of the next record starts on the same page of the previous record.
ClayDonaldsonSWCA
you could potentially use a summary/report query to accomplish similar though.
Report queries—ArcGIS Survey123 | Documentation
CarlisleHaworth1
Clay, can you share how and where you added this POST request to your flow? Is it an additional step to the usual flow that creates a report or does it replace something?
thanks!
Derrick_Westoby
I'd love to see how you did that in Power Automate too, @ClayDonaldsonSWCA . I had it working in Integromat, but can't get the call to work in Power Automate.
