Invalid Calculate for Bind
1401
12-21-2023 10:38 AM
CaitlinCaldwell
Hello, I am working in Survey123 Connect to pull data from an existing feature service when the user types in the facility name. I am using the following expression:
pulldata("@layer", "getValue", "attributes.SCRAP_TIRES_EA", 'https://maps.ihs.gov/server/rest/services/Oklahoma_SFC/OKC_Open_Dumps/FeatureServer/1,concat("FACILITY_NAME = '", ${FACILITY_NAME}, "'")
and getting the following error:
b'ODK Validate Error:\n>> XForm is invalid. See above errors. \norg.javarosa.xform.parse.XFormParseException: Invalid calculate for the bind attached to "${APPLIANCES_WHITEGOODS_EA}": couldn\t understand the expression starting at this point: ...CILITY_NAME , "\xcd\x8e\'")
DougBrowning
pulldata will always return a string.  You can try wrapping it in int like int(pulldata()) .
But pulldata often has issues with being inside a function.  So if that does not work make a temp calculate field with hidden appearance with the pulldata calc.  Then in your integer field do int(tempfield).  You can set bind esri column to null on the temp field if you do not want it in the final schema.
Hope that all makes sense
CaitlinCaldwell
Thank you for the reply! I was following the video linked below and tried switching the "type" to "decimal" rather than "integer" as was demonstrated in the video and still got the same error.
https://www.youtube.com/watch?v=sSjr8KV1HLc
Creating pulldata Functions in ArcGIS Survey123 Connect: Try out this comprehensive tutorial to learn how to seamlessly pull data from feature layers in the ArcGIS Online. Enhance your surveys with dynamic, data-driven inputs and elevate your GIS workflow. Sample pulldataffunction from feature ...
DougBrowning
No you have to wrap pulldata in int() or the 2 field trick.  Or leave as string if that is ok.
