Info button
481
06-02-2026 12:22 PM
R_Williams
We felt it would be helpful to have the opportunity to add a 'blue info button' next to a question or heading in a Survey123 form which allows the organisation creating answers and collecting the responses to be really clear on what topics the organisation particularly want to be considered by responders to the question. It also aids the responder to remain focused and informed as writing their responses.
Is there any 'current work around' for this (other than hint or notes field structure)? As we can't utilise this in a multi row table covering a multitude of topics.
Thanks 🙂
R_Williams
For example: next to flood zone the info button would clarify we are particularly interested in flood zones 2 and 3a in responses
DougBrowning
Have you tried a Guidance hint?
I tend to use groups with help images.
R_Williams
Thanks DougBrowning: Is guidance hint (floating box) available for a single select grid? And each individual row within that?
Is this more advanced option only available from Survey123Connect (as I can only add standard hints below the question/label box which isn't connected enough to each row in the 'single select grid/table' format.
Neal_t_k
MVP Regular Contributor
Not sure on the single select question, but guidance hints can only be configured using Connect, but they do work in both the field app and the web app.
