inbox map custom marker
2624
11-15-2022 02:29 AM
Gisbert61
Survey123 connect 3.16.106
I can update the marker in the geopoint part of the form using symbol=pin.png in body::esri:style after adding the png to the media folder. Works like a charm.
But I would like to update the blue markers in the inbox map so they cover less of my underlying symbology. I've found a style column in the settings tab but symbol=pin doesn't seem to work.
Does anybody know how to do this? Is it possible at all?
Thanks for your time,
Bert
ZacharySutherby
Hello @Gisbert61
It is not currently possible to set a custom marker symbol appearance for the Inbox map. We have ENH-000123894 logged to support this functionality in the future.
Thank you,
Zach
ZacharySutherby
Hello @Gisbert61
Thank you,
Zach
Clint
Has this been fixed?  We have many power poles that need inspected and need a way for those out in the field to be able to identify what poles they have or have not inspected.
admincrew
I have similar but different issue in a feature report from Survey123 and it has not been solved. I tried to define the symbology in the feature layer created by my Survey123 form and it ended up very weird. I defined the symbology in the feature layer but when I ran the report, the default symbology (yellow outline, red circle) would show up WITH the symbology I chose. In other words, both symbols were mashed together. I worked with Esri Technical support and understand it is connected with the enhancement ENH-000123894
This only happens if you change the syntax in the report template to something like ${location | size:650:650 | drawingInfo:“currentLayer”}
Default report output if you define the symbology in the feature layer
