In some cases a webmap gets created after publishing a Survey
1400
07-25-2024 11:04 AM
SanchezNuñez
Good afternoon,
I would like to know when a web map gets created after publishing a Survey.
In what cases a web maps gets also generated when publishing a Survey.
Thanks
RyanUthoff
MVP Regular Contributor
When creating a Survey123 form in S123 Connect, you have the option of creating a web map when publishing the S123 form. By default, it automatically creates a map, but you can choose to not create a web map.
RyanUthoff
ChristopherCounsell
MVP Frequent Contributor
@RyanUthoff  do you know if it's possible to delete the web map after the survey has been publish?
RyanUthoff
Oh yeah, you can delete it. The web map is independent of the S123 form and is safe to delete. The web map contains the S123 feature service in it, but deleting the map won't delete the feature service or S123 form.
