Import map extent from parent object in URL parameter
579
06-01-2022 02:35 PM
SFM_TravisBott
Is it possible to somehow import the extent of a parent object into the map in Survey123?
Our workflow launches survey123 from a polygon record in Web App Builder, which is then used to capture an additional polygon in a geoshape question. As it's all browser-based it would be nice to hard code an imported extent into the xls form. What I would like to be able to do is import the extent from the parent object and use that to define the map extent for the geotace question.
Is this possible?
