Images not showing in Title in form
1615
7
06-28-2023 12:11 AM
PaulHallett1305
HI,
I am trying to use the company logo in the title of the form page.  I am aware of being able to use the logo via a question, but don't want to change the data model and hang a logo off each object.
The code I use is as follows:
Type:'note',
Label: '<p><img src="filename" style="bgcolor: #1F5780;width: 100%"/></p>'
Just just get the colour and not the logo (logo is a png with transparency on back ground)
Any ideas?  Driving me bananas, this should work
I am using Survey123 Connect
Richard_Purkis
Hi @PaulHallett1305
Thanks for raising the issue
I would double check that you have included the correct image file format as it is case sensitive and ensure it is saved in the media folder. I used your code and mine displays as expected
Hope this helps
PaulHallett1305
Hi Richard
Thanks for this.  Noticed you're using a jpg: are png's not to be used?  I tried your way and it still didn't work.
In the image I have attached, this works, however, I just wanted to use a header so as to not adjust the data model with a logo for each record.
PaulHallett1305
Hi Richard
Did you know get a chance to check my reply?
Your suggestion simply doesn't work on my Form?  Is it based on a version?  Or something else?
I really don't want to use a logo, as it changes the data model and we're in a change freeze.
Thanks in advance
Paul
Richard_Purkis
Hi @PaulHallett1305
Sorry for not getting back to you
I notice that you are using a group. I believe you may be running into this defect:
  • BUG-000158622: Images fail to display when inserted into Group labels using HTML formatting and viewed in web app
Do you agree? If you try the same html in a note does the image appear?
Hope this helps
PaulHallett1305
Hi Richard
No, that group is for a title and it actually works.
I've tried logo, and I have tried the note suggestion you made and whilst the logo works, the note doesn't, but if I use logo I have to change the data model.
It's for brading purposes but doesn't work
Cheers
Paul
Richard_Purkis
Hi @PaulHallett1305
May you share your xlsx with just the rows that concern the logo and I can look into it further
Thanks
PaulHallett1305
Hi Richard,
Note>logo>filename works
Note>example1>html doesn't work.
ideally, we'd like the html to be the one that works.
Cheers
Paul
