Image in the Guidance Hint field?
2229
06-07-2023 02:10 PM
VickiG
Hi:
I have a survey question that is integer type, (number of sets of tracks observed), but would like a picture of the tracks to be available for reference.  There is only one species we are interested in so only 1 picture (or collage picture) needed.  This is the question "tracks" on line 60 of the xlsx file.
I know how to add images to choice lists and have tried creating a note field to insert the picture into, but that seems to show all the time and takes up valuable real estate in the form.  I could see changing the integer question to a "select_one numbers" and create a choice list of integers and associate the pix with one of those.
But I was hoping there was a more straightforward way to include this picture.  The guidance hint field "lightbulb" has been very handy for including pop-up text, but is there a way to replicate this for an image?
Or some other work around I don't know about?
Thank You!
Vicki
DougBrowning
MVP Esteemed Contributor
What I do is wrap the image in a group set to collapsed and it works well.
DougBrowning
VickiG
Hi Doug:
Perfect, I knew someone out there had a clever work around 🙂
That trick will work for some other items I was pondering as well.
Thanks for your continued help!
Vicki
