Thanks Brett. I got pages and groups working as well as group relevance. I'm trying to convert a complicated ODK survey to proper Survey123 format and little things are causing major problems. I wasn't getting any errors or warnings, but certain features were just not responding properly. Pull data was not working and neither was pages and groups and group relevance. After a lot of trial and error, it turned out to be one pull data calculation for a select-multiple field. As soon as I removed that one calculation a number of features started working correctly.
Now I'm having an issue trying to implement a multi-page repeat scheme. If I don't add "field-list" to the 'begin repeat' then the 'begin repeat' label is present on every page of the survey. If I do add “field-list” to the 'begin repeat', then I can’t add subsequent pages using ‘begin group’, “field-list”, until after I do “end repeat’.
Also when I use relevance on an entire group, and the relevance criteria are not met, it seems to leave a blank page in the survey, instead of just completely skipping the group. Is there a way to just skip a non-relevant group without showing a blank page?
-Andy
