If then expressions
2410
02-07-2016 06:48 PM
AddieZannes
I can see that XLSForm supports expressions such as "if ((${a} = 0 and ${b} = 0) or (${a} = 1 and ${b} = 1), 1, 0)".  Can this calculation be done in Survey123?
Tags (1)
DanPatterson_Retired
You would be advised to consult the available information Survey123 for ArcGIS since it is in beta and any documentation would be limited to it.
AddieZannes
Thanks Dan. Yes I have had a look at the doco, forums and blog with no luck.  Was going to throw the question out there to see if any users had the answer. Cheers.
RebeccaStrauch__GISP
It would be best to try Moving Content​  ....but for now, I'll tag Survey123 for ArcGIS​  which should get you a more focused group.
