if Statement for Map Questions in Survey 123 Connect
752
05-09-2024 09:12 AM
MonmouthNJGIS
Howdy! My organization is attempting to have a geopoint question automatically center on a specified location based on a previous answer. Our research led us to using an if statement and having the coordinates entered in the following syntax: concat('40.293474497282965', ' ', '-74.30371444582654')
We came up with the following if statement but it keeps returning the following error:
Error: ...cannot handle function 'if' requires arguments. Only 4 provided...
Statement: if(${do_members_of_your_household_us}, 'Headquarters_Manalapan', concat('40.293474497282965', ' ', '-74.30371444582654'), if(${do_members_of_your_household_us}, 'Eastern_Branch_Shrewsbury', concat('40.318380142105774', ' ', '-74.06151036074922'), concat('40.265', ' ', '-74.251')))
DougBrowning
MVP Esteemed Contributor
you do not have any = or selected at all.
Try this
if(${do_members_of_your_household_us} = 'Headquarters_Manalapan', concat('40.293474497282965', ' ', '-74.30371444582654'), if(${do_members_of_your_household_us} = 'Eastern_Branch_Shrewsbury', concat('40.318380142105774', ' ', '-74.06151036074922'), concat('40.265', ' ', '-74.251')))
DougBrowning
Try this
MonmouthNJGIS
Thanks! we got some conflicting examples that did and didn't use an "=". This is the final statement we came up with:
if(${do_members_of_your_household_us} = 'Headquarters_Manalapan', "40.293474497282965 -74.30371444582654",
if(${do_members_of_your_household_us} = 'Eastern_Branch_Shrewsbury', "40.318380142105774 -74.06151036074922",
"40.265 -74.251"))
DougBrowning
You probably saw examples use selected.  Works the same in select one but if this was a select multiple then you would have to use it.
selected(question, value)
Checks whether answer is selected. This function is used for select_one and select_multiple questions.
selected(${question_one}, 'a')
Would look like
if(selected(${do_members_of_your_household_us},'Headquarters_Manalapan'), "40.293474497282965 -74.30371444582654",
if(selected((${do_members_of_your_household_us},'Eastern_Branch_Shrewsbury'), "40.318380142105774 -74.06151036074922",
"40.265 -74.251"))
