IF and Then Statement Survey123
843
09-03-2024 07:48 AM
ablum
I'm trying to write a calculation for a Status cell based multiple other cells.
Basically if cells A2, B2, C2, D2, E2 ='Pass' or 'Partial' then Status will equal 'PASS', but if any of them equal Fail, one 'Fail' should overwrite all Passes.
Example:
A2 ='Pass' or 'Partial', B2 ='Pass' or 'Partial', C2 ='Pass' or 'Partial', D2 ='Pass' or 'Partial', E2 ='Pass' or 'Partial'
Status='PASS'
Example 2:
A2 ='Pass' or 'Partial', B2 ='Pass' or 'Partial', C2 ='Pass' or 'Partial', D2 ='Pass' or 'Partial', E2 ='Fail'
Status='FAIL'
jcarlson
It should be pretty easy with an if function. Rather than function the cells, use the field name. Try this:
if(${field1} = 'Fail' or ${field2} = 'Fail' or ${field3} = 'Fail' or ${field4} = 'Fail' or ${field5} = 'Fail', 'FAIL', 'PASS')
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
ablum
That worked, thank you!
