I try to make a new survey then I get an error " Unable to create a new survey. Cannot perform query. Invalid query parameters."
1593
16
07-21-2018 08:59 PM
nicoletrenholm
Why does my account give me this error?
Why can I not make a new survey?
DanPatterson_Retired
Have you confirmed the requirements?
System requirements—Survey123 for ArcGIS | ArcGIS
Have you been able to create one before?
If not, try the exercises beginning with...
Create an ArcGIS organization—Survey123 for ArcGIS | ArcGIS
nicoletrenholm
My computer meets the requirements. I was able to create a survey when I was a trial member.
so you are with an organization?
by Anonymous User
Not applicable
Hi Nicole,
Are you using ArcGIS Online or Enterprise (Portal)? And are you trying to create surveys using Connect or Web Designer?
You need to ensure you are a level 2 user to create surveys.
Phil.
nicoletrenholm
I am a level 2 user with an organization and am using ArcGis Onine
by Anonymous User
Not applicable
Hi Nicole,
So where do you see the error message you describe above, can you send a screenshot?
Phil.
nicoletrenholm
nicoletrenholm
If I try and open an existing survey
by Anonymous User
Not applicable
Hi Nicole,
I see you are logged in with a gmail account? Do you have a paid ArcGIS Online subscription?
Phil.
