I keep getting an error stating that a folder cannot be created when I try to publish my survey from survey123 connect. !
1353
04-15-2020 03:21 PM
by Anonymous User
Not applicable
Can someone please help? I have attached my survey so you can see what I have done. I don't get any sort of error message when I preview my form so I am at a loss as to why my survey won't publish. This is my very first survey to be published. Thank you for your help
IsmaelChivite
Esri Notable Contributor
This happens when Connect attempts to create a folder that already exists.
Try the following:
  • Log into your portal and to your Content
  • Look for your survey folder and delete it (check to see if there is anything important in it first!)
  • Back into Connect, open your survey folder and delete the file with extension .iteminfo
  • Publish again
by Anonymous User
Not applicable
I did what you suggested and the error still occurred.
by Anonymous User
Not applicable
I tried that and still received the same error…
