How to transfer Survey123 records from ArcGIS Online to Portal?
1377
09-28-2019 12:14 PM
HossamAl_jabri1
Hey friends,
I have many records in survey123 website which submitted through ArcGIS Online and my organization decided to use a Portal for ArcGIS. So, is there any possibilities to transfer all records from ArcGIS Online to Portal?
JamesTedrick
Esri Esteemed Contributor
Hi Hossam,
The easiest way to migrate records is to export a file geodatabase of the records (either through Surey123 or the Item Details page) and then import the data into your ArcGIS Enterprise installation whether you import into an enterprise geodatabase or the hosted feature store.
