How to setup Survey123 to write to an existing feature layer on AGOL?
1097
03-16-2017 12:36 PM
NickToscano
Do I need to create the survey and then switch out the feature layer that is there with another one in the folder?
JamesTedrick
Esri Esteemed Contributor
Hi Nick,
It's better to create a survey from your existing feature service already.  Use Survey123 with ArcGIS Server—Survey123 for ArcGIS | ArcGIS  Describes using Survey123 with existing services.
