Hi everyone,
I’m working on a Survey123 Connect project that involves two linked view layers created from one main feature layer.
Main feature layer: Best_Staff_Management_Collation
HR view layer: used by the HR team to enter staff performance data each quarter.
Important field: Percentage_Score
GM view layer: used by the GM team to enter their own data each quarter for each staff.
In this form, I want to automatically pull the latest Percentage_Score from the HR view layer for that staff.
Each HR record includes:
Name — staff name
Percentage_Score — quarterly performance result
CreationDate — (system field that captures when the record was created)
This is my expression, but it is not pulling the lastest record for quarter 3 : pulldata("@layer","getValue","attributes.Percentage_Score","https://services1.arcgis.com/m9p5y180BqMf6JT7/arcgis/rest/services/Best_Staff_Management_Collation_3...", concat("Name='", ${Name},"'"))
Solved! Go to Solution.
To get the latest you would add a SQL query. See this post https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-pulldata-quot-laye...
and this one https://community.esri.com/t5/arcgis-survey123-questions/is-it-possible-within-a-survey123-smart-for...
Something like orderby may be what you want
pulldata("@layer", "getRecord","<your_featurelayer_url>?orderByFields=CreationDate DESC", "1=1")
Hope that helps
Hope that helps
