How to print-multiple-records-in-one-survey123-report
1989
05-11-2021 05:04 AM
srikanthnamburi3
How to print-multiple-records-in-one-survey123-report, any example we can guide.
ZacharySutherby
Hello @srikanthnamburi3
If you have multiple records selected in the Data tab of the ArcGIS Survey123 website you can include those records in one report under file options you can choose to merge them into a single file placing each record on the next page, or a continuous page.
As a note if you are using ArcGIS Online including multiple records in one report the report is charged 0.5 per survey record. For example, 2 records in one report will cost 1 credit, 0.5 for each record.
Please use this link for more information on printing survey results.
Thank you,
Zach
Thank you,
Zach
srikanthnamburi3
Unfortunately not working, what are the changes to be done in template.  any guidance.
ZacharySutherby
Can you please elaborate some more on what isn't working? What was returned in the report vs what are you looking for the report to return?
Please use this link for the documentation on printing reports: https://doc.arcgis.com/en/survey123/browser/analyze-results/printsurveyresults.htm#ESRI_SECTION1_2A4...
Thank you,
Zach
Thank you,
Zach
srikanthnamburi3
I collect information from survey like this
Record 1
1  user a valve hydrant temp
Record 2
2  user b valve 2 hydrant temp2
Need a single report in one page like a table. when using continuous  its not working.
id user   valveinfo  hydrant info temp
1  user a valve hydrant temp1
2  user b valve 2 hydrant temp 2
