How to populate a field based on a previous fields answer?
2121
09-14-2021 06:06 AM
DaveK
Hello!
I'm creating a survey for field inspections. I would like to have the user select from a drop down (select_one) of inspection sites and then have the next field auto populate with information related to that site. I understand how to do this using a choice_filter if that field is another select_one, but my goal is to have the next field as text just in case the user has to edit the entry. Is this possible within survey123 connect? any help is appreciated.
Thanks.
DougBrowning
MVP Esteemed Contributor
DaveK
Thanks @DougBrowning , The pulldata worked perfectly!
