Is is possible to open a new survey that I started creating on the web in survey123 connect?
Hi Nicole,
Yes, it is supported. When you login via the Survey123 Connect application, you will see both the surveys you've authored in Survey123 Connect and the Survey123 website.
Hi. Not at the moment, but we are working towards making this possible in an upcoming release.
Is this supported now?
Hi Nicole,
Thanks James, found it!
