In order to make a line graph in the dashboard showing the cumulative number of corona cases, I need to create a hidden field in my Survey which automatically counts the numers of records. Is there a way of doing this?
My idea was to create a hidden field "def1" which has a default value of 1. Then I created a second hidden field which
calculated the total of the first hidden field i.e. sum(${def1})
This fails though. Could anyone help?survey
Hi Robert,
There isn't a way in Survey123 to calculate the total number of submissions (a cumulative count); I also don't think that's quite the correct way to work with that, as it would be possibly too fine grained (submission by submission).
One idea would be to have a feature layer that has a table of dates and a field to store the cumulative number of cases; you could then use an Arcade function to do a field calculation (utilizing one of the FeatureSet options) - you would be able to create a field calculation based on the number of cases less than the date (using the Filter function to do the query). What’s new with Arcade: Taking a stroll through FeatureSets (Part 1) Provides a starting point to working with this functionality.
Also asking ArcGIS Online and Operations Dashboard for ArcGIS for their ideas.
Been trying to figure this out all night, but unfortunately with no success. For a start, I cant summarize or use any featureset functions to display labels. If you have an example of how this works, i would be grateful
