How to add multiple images to an answer choice in select_one question
1426
06-08-2022 07:10 AM
leightmaes
Hello,
I'd like to add two images to each possible answer in a select_one question. I know already how to add media and have successfully added one image to each possible answer in Survey123 Connect, but I'm not sure how (or if it's possible) to add two images to an answer choice for a select_one question in the Choices tab of the S123 Connect spreadsheet in the meda::image column. If this is possible, does anyone know what the syntax might be? I have tried simple & and && with no success.
Thanks in advance to anyone who might have advice.
DougBrowning
MVP Esteemed Contributor
Not sure but Just use a photo editor to make it into one photo.  That way you can lay it out how you want anyway.  Hope that helps.
This is how I do it and it looks nice
DougBrowning
leightmaes
Thanks, Doug, this will do the trick.
