How is a Selected List Item Used to Select the Next List to Display?
1071
08-28-2022 04:11 PM
vocono1953
Hi. I’m working on a Surver123 Connect project. My experience developing apps is as a programmer and have no experience working with ESRI products.
What is needed is to use the selected ‘ListTaskType’ to display ListTask. Two lines from the survey sheet:
select_one list_task_type
ListTaskType
Types of Task
select_multiple list_task
ListTask
Tasks
I’m not certain how (in)correct the above is, but the followings choice sheet probably incorrect:
list_task_type
Hort Area
list_task_type
Greenhouse
list_task_type
Lawn/Turf
list_task_type
Other Tasks
if (${ListTaskType}=0) then
Clean
Prune
Plant
Water
if (${ListTaskType}=2) then
Aerate
Amend soil
Manage Pests
Mow
The IF statement is in the wrong column—don’t know where it goes. Not certain if the operator $ is correctly used. Tried to Google smaller questions with no good result.  Thank you for any help you offer.
--Bob
LaurenceTait
What you need is cascading select: https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformcascadingselects.htm. You need to add another column to your choices tab that tells the app which task is relevant to which task _type, and then add an expression to the [choice_filter] column of the survey tab to tell the app what to filter on.
Example attached below
LaurenceTait
vocono1953
Thank you, Laurence. That is what I needed 🙂
