How is a Date Displayed as Read Only Text in Survey123 Connect?
1924
8
11-15-2022 12:07 PM
vocono1953
The function format-date was used to do this. Placing Today as an inline function call was rejected. Survey sees Today an element that does not exist in the app.
Also, I don't know what field format-date is placed.
Thank you for your help.
--Bob
JenniferAcunto
format-date(today(), '%Y/%m/%d %H:%M')
- Jen
ZacharySutherby
Hello @vocono1953
Try placing format-date(today(), '%Y/%m/%d') in the calculate column of the XLSForm. Please see this documentation for more information on the format-date function.
Thank you,
Zach
vocono1953
Hi Zach,
Thank you for the advice. I paced it in the calculate column and the same error remains. It rejects the use of Date() as input. It may not be possible to do this. Any more thoughts?
Thanks again.
IsmaelChivite
Esri Notable Contributor
today() should all be lowercase.
vocono1953
Thank you for your input, Ismael. However, it resulted in the same error.
Thanks anyway.
JenniferAcunto
The error shows ${Today()}. Did you put Today() as the question name? today() should be in the calculation column and your question name needs to be something like date_today and not a function.
It would be helpful at this point to include your survey XLS.
- Jen
vocono1953
OK, Jennifer. Here is the XLS file. Please look at line 4.
Thanks for the help.
JenniferAcunto
- Jen
vocono1953
Very nice! That fixed it.
Thank you.
