How do I display data from repeat records based on a parent field in a feature layer in my survey123
1975
07-01-2024 02:07 AM
AndrewHarrington1
Looking for some help. I have a feature layer with a list of Pits and I have a related table that has many records and is linked to the Pit layer through a parent_asset_code field in the related table.
For example PIT-002054 is selected from the primary feature layer and it has 4 records in the related table each with PIT-002054 as the parent_asset_code and each record has some data in it including 'Design Quantity' field and I am using the form to view these and add a number into the 'Actual Quantity' field to each of the records. I want to be able to scroll through each record to review the data. This should come from the Feature layer.
I have used the pulldata function and only managed to retrieve one record (and I have to press the + button to even get that). I am unable to pull data for all the records and I have tried so many things including position(..) and some json but I am a useless coder!
I would be grateful if someone could point me in the right direction.
Here is a sample of my current xml file
DougBrowning
MVP Esteemed Contributor
Are you trying to create multiple repeat records at once?  If so, then no you cannot do that.
AndrewHarrington1
Hi Doug, No I am just trying to view repeat records from an existing feature layer and related table using the Survey123 app by pulling the data into the survey form. I just cannot get the form to show me all the records so I can scroll though the number of records (repeats) for the parent asset.
Basically I just want to pull from an existing feature layer and related table into a survey form and make edits on a couple of fields in each related record.
jamiehollingsworth
i am trying to create something very similar, were you able to come up with a solution?
later
j
LeoDCG
Same, trying to pull data from a parent record and have the form display the related records for editing.
DougBrowning
This sounds more like a use case for inbox.  https://learn.arcgis.com/en/projects/enable-an-inbox-for-a-census-survey/  I do not think pulldata is meant to pull that much data.
