How can I modify the basemap of a feature report?
1384
05-18-2020 08:28 AM
MichaelShoemaker
Hello!
The geopoint maps within my feature report are outputting in the "streets" basemap. Can I change this to aerial somehow? I looked around for some documentation on how to edit the template but I have not found it yet.
My survey is set up with a master parent point with repeating related points, if that is relevant.
Thanks!
report survey123‌ survey123 designer‌
Shwu-jingJeng
Hi Michael,
Yes, this is possible. You can specify a web item id in the syntax as the following example:
${location|mapSettings:"10df2279f9684e4a9f6a7f08febac2a9":100000}
It's documented here:
Feature report templates—Survey123 for ArcGIS | Documentation
MichelleWilliamsERM
Good day to you,
Is it true that I can only use webmaps with one layer (3.18)?
One layer seems to work in the Feature Report, but I'd really like to have two. BUT when I have two layers, the software times out.
Thanks for any help you can share.
${NestLocation | map:"b261473bce524ec08e07ce461d26ebe1"}
UPDATED: After getting the map to work with one layer, I added the 2nd layer to see if it would work, and it did. WEIRD!
