I have a survey that asks for the dat and time a sample was collected and incubated. This survey is linked to a Feature Service in my ArcGIS server environment which references data in my company's locally hosted database, SQL Server.
Whilst creating a report for the data entered from the survey I discovered that the timestamp is set in UTC time, which is a 6 hour difference from my time.
I set this calculated field in the 123 Connect form, however this doesn't seem to work as nothing is inserted into that column in the database when submitting a survey:
How can I overcome this? My time zone is UTC -6
Hi Kristin
There are a couple of methods that might help.
While date/time fields in a feature service are stored in UTC, Survey123 (and other ArcGIS applications) will display the date/time in your local time zone. You can save this value (in local time zone) to a string using the format-date() function. For example, using a calculation similar to this in a text question:
format-date(${datetime1},'%d/%m/%Y %H:%M')
If you need the 'local' date/time to stay in date/time format, you could use something similar to your calculation above but with a slight correction. The pulldata("@property", 'utcoffset') expression returns the UTC offset in hours for your location. Multiply this offset by 1000 * 60 * 60 to get milliseconds (for Epoch time). So your calculation would look like:
${datetime1} + (pulldata("@property", 'utcoffset') * 1000 * 60 * 60)
Note that Epoch (UNIX) time calculations work well in the Survey123 field app but not in the web app; if you're using your survey in both the field app and the web app it'd be better to use decimal time for your calculations. There are a set of formulas for converting to decimal time.
See this blog for more detail and useful examples: https://community.esri.com/groups/survey123/blog/2016/04/17/dates-and-time-in-survey123-for-arcgis
And this help topic on dates and times in Survey123: Decimal date time—Survey123 for ArcGIS | Documentation
Hope this helps
Best,
Jim
Hello thanks for the response. I updated the calculation but my problem is that when submitting a form the datetime value is not calculated and inserted in that field. Is there something else I should add?
Hi Kristin
Would it be possible to provide your XLSForm so I can take a closer look? You can attach files to a GeoNet reply using the advanced editor.
Jim
