Is there a way to add a repeat to my published survey without building a new one and appending the data?
Looking forward to the answers on this one, but I doubt there's a way without appending.
Unfortunately not. When you add a repeat to your survey, Connect will not be able to simply add the related table to your existing survey layer. Instead, it creates a new layer. Some options that come to mind:
Option 1:
Option 2:
Option 3:
Thank you for these suggestions @IsmaelChivite
Option 1 - I've never considered overriding the service on purpose (to keep the id intact).
I will try these next week. : )
I have tried the first option, but i lost the attachments. Any solution???
@IsmaelChivite Does Option 3 mean that the data does not get deleted?
Technical Support has a detailed step-by-step article for this situation. I've followed it twice.
That article link is broken - do you think there is a way to find it?
