I have noticed that when you create a copy of a survey from the Sent box the repeats for the original survey are removed. Is this the software design for how repeats are managed within the Sent box?
Below is the example of the workflow I am using.
This removes the history of capturing repeats for previous surveys. What is the reason for removing the repeats for the original survey?
Thank you,
Kevin
Hi Kevin,
Can you look through https://community.esri.com/message/747929-copying-repeats-to-new-surveys-not-working#comment-750605 ? This sounds like the bug uncovered in that thread.
Hello James,
I read the linked question and it seem to have similar workflow to my question.
One thing I remembered is that if you open the original survey again to edit, the repeat does show. If you save and send now the repeat shows in the service. However, if you make a new copy, then the original does not show the repeat.
I have attached my XLS form.
Thank you,
Kevin
Hello James,
Could you please verify if the Sent Box issue I have described is related to the bug you mentioned?
Thank you,
Kevin
Hi Kevin,
Yes the issue you are experiencing is identical to the issue I cited above.
