Hi, uninstalling/deleting Old Versions of 123....
1158
06-19-2018 06:19 AM
johnmosheim1
I have older versions of Survey123 Connect & Survey123 Online, I would like to uninstall or delete, the older versions do not appear on the list of installed programs, only the newest version I just installed of both programs do. I renamed the old 123folders Old_....to avoid any criss crossing. Thanks for any suggestions-I'd like to delete/unisntall old ones if possible John
by Anonymous User
Not applicable
Hi John,
Currently only installing one version of Survey123 is supported. If you have installed multiple versions to multiple different folders, if they are not appearing in your Control Panel -> Programs and Features and are not appearing in Start Menu app shortcuts, then you can simple delete the folders that you no longer require. This will fully remove the app and installation files.
Phil.
johnmosheim1
Philip:
Sorry for not replying before. I did that, I'll see what happens ok?
John
