Having problems accessing survey data
1455
04-06-2020 05:43 AM
JamieKelly1
After log indata tab of NPH Condition Inspection
so upon login I am seeing cors request errors and then when i go to the overview of the NPH Condition Inspection it is intermittently working, but trying to go to the data tab either gives me a forever loading or sometimes I will get an error telling me the survey doesn't exist.  I've opened the developer toolbar in Google Chrome (That's the browser I've been using) so you can see the console messages.  Looks like something to do with CORS.
JamesTedrick
Esri Esteemed Contributor
Hello,
It appears you may have been affected by a temporary issue with ArcGIS Online Feature Services - see the note for today at https://status.arcgis.com
NicholasDay
Myself and a coworker are running into connection issues also. Surveys fail to submit, cannot access the data in survey123 website or AGOL Content, publishing fails, etc.
JamesTedrick
Hello,
JamieKelly1
I found the status page after I posted.  Once the issue was resolved, everything worked normally.
